The M_COPYIN message is generated by a module or driver and sent upstream to request that the stream head perform a copyin(9F) on behalf of the module or driver. It is valid only after receiving an M_IOCTL message and before an M_IOCACK or M_IOCNAK.
The message format is one M_COPYIN message block containing a copyreq(9S) structure, defined in <sys/stream.h>. Different structures are defined for 64–bit and 32–bit architectures.
#if defined(_LP64) struct copyreq { int cq_cmd; /* ioctl command (from ioc_cmd) */ cred_t *cq_cr; /* full credentials (from ioc_cmd) */ uint cq_id; /* ioctl id (from ioc_id) */ uint cq_flag; /* see below */ mblk_t *cq_private; /* private state information */ caddr_t cq_addr; /* address to copy data to/from */ size_t cq_size; /* number of bytes to copy */ }; #else struct copyreq { int cq_cmd; /* ioctl command (from ioc_cmd) */ cred_t *cq_cr; /* full credentials */ uint cq_id; /* ioctl id (from ioc_id) */ caddr_t cq_addr; /* address to copy data to/from */ size_t cq_size; /* number of bytes to copy */ uint cq_flag; /* see below */ mblk_t *cq_private; /* private state information */ int cq_filler[4]; /* reserved for future use */ }; #endif /* _LP64 */ |
The first four members of the structure correspond to those of the iocblk(9S) structure in the M_IOCTL message that allows the same message block to be reused for both structures. The stream head guarantees that the message block allocated for the M_IOCTL message is large enough to contain a copyreq(9S). The cq_addr field contains the user space address from which the data is to be copied. The cq_size field is the number of bytes to copy from user space. The cq_flag field is reserved for future use and should be set to zero.
This message should not be queued by a module or driver unless it intends to process the data for the ioctl(2).
