STREAMS Programming Guide
Unloading a Module that Uses esballoc
The STREAMS framework prevents a module or driver text from being unloaded while there are open instances of the module or driver. If a module does not cancel all callbacks in the last close routine, it should not be allowed to be unloaded.
This is an issue mainly for modules and drivers using esballoc because esballoc callbacks cannot be canceled. Thus, modules and drivers using esballoc have to be prepared to handle calls to the esballoc callback free function after the last instance of the module or driver has been closed.
Modules and drivers can maintain a semaphore count of outstanding callbacks. They can deny an unload by making the _fini(9E) routine return EBUSY if there are outstanding callbacks.
