STREAMS Programming Guide
Preface
The STREAMS Programming Guide describes how to use STREAMS in designing and implementing applications and STREAMS modules and drivers, for architectures that conform to the SolarisTM 7 DDI/DDK.
Who Should Use This Book
This manual is a guide for application, driver, and module developers. The reader must know C programming in a UNIXTM environment, and be familiar with the system interfaces. Driver and module developers should also be familiar with the book Writing Device Drivers.
How This Book Is Organized
This guide is divided into three parts. Part 1, Application Programming Interface, describes how to use STREAMS facilities in applications. Part 2, Kernel Interface, describes how to design STREAMS modules and STREAMS drivers. Part 3, Advanced Topics, contains advanced topics. Every developer should read Chapter 1.
Part 4, Appendixes
Related Books
You can obtain more information on STREAMS system calls and utilities from the on-line manual pages. For more information on driver-related issues, including autoconfiguration, see Writing Device Drivers.
You can also find STREAMS described to some extent in the System V Interface Definition, and in the following publications:
Goodheart, Berny and Cox, James. The Magic Garden Explained. Australia, & Englewood Cliffs, New Jersey: Prentice Hall, 1994.
Rago, Stephen A. UNIX System V Network Programming. Reading, Massachusetts: Addison-Wesley, 1993.
Accessing Sun Documentation Online
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
Typographic Conventions
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions
Typeface or Symbol
Meaning
Example
AaBbCc123
 The names of commands, files, and directories; on-screen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
 What you type, contrasted with on-screen computer output
machine_name% su
Password:
AaBbCc123
 Command-line placeholder: replace with a real name or value
To delete a file, type rm filename.
AaBbCc123
Book titles, new words, or terms, or words to be emphasized.
Read Chapter 6 in User's Guide.
These are called class options.
You must be root to do this.
Shell Prompts in Command Examples
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
Shell
Prompt
 C shell promptmachine_name%
 C shell superuser promptmachine_name#
 Bourne shell and Korn shell prompt$
 Bourne shell and Korn shell superuser prompt#
