Each instantiation of ptem(7M) is associated with a local area. These data are held in a structure called ptem that has the following format:
struct ptem { long cflags; /* copy of c_flags */ mblk_t *dack_ptr; /* pointer to preallocated msg blk used to send disconnect */ queue_t *q_ptr; /* pointer to ptem's read queue */ struct winsize wsz; /*struct to hold windowing info*/ unsigned short state; /* state of ptem entry */ };
When ptem(7M) is pushed onto the slave side stream, a search of the ptem structure is made for a free entry (state is not set to INUSE). The c_cflags of the termio(7I) structure and the windowing variables are stored in cflags and wsz respectively. The dack_ptr is a pointer to a message block used to send a zero-length message whenever a hang-up occurs on the slave side.
ptem(7M) internal implementation might change. This structure should be relevant only to people wanting to change the module.
