International Language Environments Guide
TTY Environment Setup
Depending on the terminal and terminal emulator that you are using, you might need to push certain codeset-specific STREAMS modules onto your streams.
For more information on STREAMS modules and streams in general, see the STREAMS Programming Guide.
The following table shows STREAMS modules supported by the en_US.UTF-8 locale in the terminal environment.
Table 5–7 32–bit STREAMS Modules Supported by en_US.UTF-8
Description
/usr/kernel/strmod/u8lat1
Code conversion STREAMS module between UTF-8 and ISO8859–1 (Western European)
/usr/kernel/strmod/u8lat2
Code conversion STREAMS module between UTF-8 and ISO8859–2 (Eastern European)
/usr/kernel/strmod/u8koi8
Code conversion STREAMS module between UTF-8 and KOI8–R (Cyrillic)
The following table lists the 64–bit STREAMS modules supported by en_US.UTF-8.
Table 5–8 64–bit STREAMS Modules Supported by en_US.UTF-8
64-bit STREAMS module
Description
/usr/kernel/strmod/sparcv9/u8lat1
Code conversion STREAMS module between UTF-8 and ISO8859-1 (Western European)
/usr/kernel/strmod/sparcv9/u8lat2
Code conversion STREAMS module between UTF-8 and ISO8859-2 (Eastern European)
/usr/kernel/strmod/sparcv9/u8koi8
Code conversion STREAMS module between UTF-8 and KOI8-R (Cyrillic)
Loading a STREAMS Module at Kernel
To load a STREAMS module at kernel, first become root.
To determine whether you are running a 64-bit Solaris or 32-bit Solaris system, use the isainfo(1) utility as follows:
system# isainfo -v
64-bit sparcv9 applications
32-bit sparc applications
If the command returns this information, you are running the 64-bit Solaris system. If you are running the 32-bit Solaris system, the utility shows the following:
system# isainfo -v
Use modinfo(1M) to be certain that your system has not already loaded the STREAMS module:
system# modinfo | grep  modulename
If the STREAMS module, such as u8lat1, is already installed, the output looks as follows:
system# modinfo | grep u8lat1
89 ff798000  4b13  18   1  u8lat1 (UTF-8 <--> ISO 8859-1 module)
If the module is already installed, you do not need to load it. However, if the module has not yet been loaded, use modload(1M) as follows:
system# modload /usr/kernel/strmod/u8lat1
This command loads the 32–bit u8lat1 STREAMS module at the kernel so you can push it onto a stream. If you are running the 64–bit Solaris product, use modload(1M) as follows:
system# modload /usr/kernel/strmod/sparcv9/u8lat1
The STREAMS module is loaded at the kernel and you can now push it onto a stream.
To unload a module from the kernel, use modunload(1M), as shown below. In this example, the u8lat1 module is being unloaded.
system# modunload -i 89
dtterm and Terminals Capable of Input and Output of UTF-8 Characters
Unlike in previous releases of the Solaris operating environment, the dtterm(1) Terminal and any other terminals that support input and output of the UTF-8 codeset do not need to have any additional STREAMS modules in their stream. ldterm(7M) module is now codeset independent and supports Unicode/UTF-8 as well.
To set up the proper terminal environment for the Unicode locales, use the stty(1) utility. To query the current settings use the -a option of the stty(1) utility, as shown below:
system% /bin/stty -a
Note –
Because /usr/ucb/stty is not internationalized, use /bin/stty instead.
Terminal Support for Latin-1, Latin-2, or KOI8-R
For terminals that support only Latin-1 (ISO8859-1), Latin-2 (ISO8859-2), or KOI8-R, you should have the following STREAMS configuration:
head <-> ttcompat <->  ldterm <->  u8lat1 <-> TTY
This configuration is only for terminals that support Latin-1. For Latin-2 terminals, replace the STREAMS module u8lat1 with u8lat2. For KOI8-R terminals, replace the module with u8koi8.
Make sure you already have the STREAMS module loaded into the kernel.
To set up the STREAMS configuration shown above, use strchg(1M), as shown in the second command line of the example:
system% cat > tmp/mystreams
ttcompat
ldterm
u8lat1
ptem
^D
system% strchg -f /tmp/mystreams
Be sure that you are either root or the owner of the device when you use strchg(1). To see the current configuration, use strconf(1) as follows:
system% strconf
ttcompat
ldterm
u8lat1
ptem
pts
system%
To reset the original configuration, set the STREAMS configuration as follows:
system% cat > /tmp/orgstreams
ttcompat
ldterm
ptem
^D
system% strchg -f /tmp/orgstreams
Saving the Settings in ~/.cshrc
Assuming the necessary STREAMS modules are already loaded with the kernel, you can save the following lines in your .cshrc file (C shell example) for convenience:
setenv LANG en_US.UTF-8
if ($?USER != 0 && $?prompt != 0) then
     cat >! /tmp/mystreams$$ << _EOF
     ttcompat
     ldtterm
     u8lat1
     ptem
_EOF
     /bin/strchg -f /tmp/mystreams$$
     /bin/rm -f /tmp/mystreams$$
     /bin/stty cs8 -istrip defeucw
endif
With these lines in your.cshrc file, you do not have to type all of the commands each time you use the STREAMS module. Note that the second _EOF should start from the first column of the file.
