The WBEM server writes audit records for certain events during processing. For example, the WBEM server writes audit records whenever the authentication of a client succeeds or fails, and whenever an operation that modifies user information is executed.
The WBEM server uses the underlying Solaris Basic Security Module (BSM) to write its audit records. You must enable the BSM auditing mechanism (bsmconv) in the Solaris operating environment on the WBEM server to ensure that audit information is recorded. This command is described in bsmconv(1M).
If you are using Trusted SolarisTM, you do not need to enable the BSM auditing mechanism.
