Solaris WBEM Services Administration Guide
If Other CIM Security Exception Errors Appear
The WBEM server can return other error indications in the CIM security exception. However, these indications typically identify a system failure in the authentication exchange. The WBEM client configuration might not be compatible with the WBEM server configuration for the security options in the authentication exchange.
If these error indications occur, check that the WBEM installation on the client machine contains the appropriate configuration property values for security in WbemClient.properties. This file is usually located in the vendor extension subdirectory in the WBEM installation directory /usr/sadm/lib/wbem/extension.
Also, check the client application CLASSPATH setting to ensure that sunwbem.jar and the extension directory path name are on the class path.
