Multithreaded Programming Guide
pthread_attr_init(3THR)
Use pthread_attr_init(3THR) to initialize object attributes to their default values. The storage is allocated by the thread system during execution.
Prototype:
int pthread_attr_init(pthread_attr_t *tattr);
#include <pthread.h>
pthread_attr_t tattr;
int ret;
/* initialize an attribute to the default value */
ret = pthread_attr_init(&tattr);
Table 3–1 shows the default values for attributes (tattr) .
Table 3–1 Default Attribute Values for tattr
Attribute
Value
Result
scope
PTHREAD_SCOPE_PROCESS
New thread is unbound – not permanently attached to LWP.
detachstate
PTHREAD_CREATE_JOINABLE
Exit status and thread are preserved after the thread terminates.
stackaddr
NULL
New thread has system-allocated stack address.
stacksize
New thread has system-defined stack size.
priority
New thread has priority 0.
inheritsched
PTHREAD_EXPLICIT_SCHED
New thread does not inherit parent thread scheduling priority.
schedpolicy
SCHED_OTHER
New thread uses Solaris-defined fixed priorities for synchronization object contention; threads run until preempted or until they block or yield.
Return Values
pthread_attr_init() returns zero after completing successfully. Any other return value indicates that an error occurred. If the following condition occurs, the function fails and returns the corresponding value.
ENOMEM
Returned when there is not enough memory to initialize the thread attributes object.
