Multithreaded Programming Guide
Using mdb(1)
The following mdb commands can be used to access the LWPs of a multithreaded program.
Table 7–3 MT mdb Commands
pid:A
Attaches to process # pid. This stops the process and all its LWPs.
:R
Detaches from process. This resumes the process and all its LWPs.
$L
Lists all active LWPs in the (stopped) process.
n:l
Switches focus to LWP # n.
$l
Shows the LWP currently focused.
num:i
Ignores signal number num.
These commands to set conditional breakpoints are often useful.
Table 7–4 Setting mdb Breakpoints
[label],[count]:b [expression]
Breakpoint is detected when expression equals zero
foo,ffff:b <g7-0xabcdef
Stop at foo when g7 = the hex value 0xABCDEF
