Multithreaded Programming Guide
Peterson's Algorithm
The code in Example 9–6is an implementation of Peterson's Algorithm, which handles mutual exclusion between two threads. This code tries to guarantee that there is never more than one thread in the critical section and that, when a thread calls mut_excl(), it enters the critical section sometime “soon.”
An assumption here is that a thread exits fairly quickly after entering the critical section.
Example 9–6 Mutual Exclusion for Two Threads?
void mut_excl(int me /* 0 or 1 */) {
    static int loser;
    static int interested[2] = {0, 0};
    int other; /* local variable */
    other = 1 - me;
    interested[me] = 1;
    loser = me;
    while (loser == me && interested[other])
    /* critical section */
    interested[me] = 0;
This algorithm works some of the time when it is assumed that the multiprocessor has strongly ordered memory.
Some multiprocessors, including some SPARC-based multiprocessors, have store buffers. When a thread issues a store instruction, the data is put into a store buffer. The buffer contents are eventually sent to the cache, but not necessarily right away. (Note that the caches on each of the processors maintain a consistent view of memory, but modified data does not reach the cache right away.)
When multiple memory locations are stored into, the changes reach the cache (and memory) in the correct order, but possibly after a delay. SPARC-based multiprocessors with this property are said to have total store order (TSO).
When one processor stores into location A and then loads from location B, and another processor stores into location B and loads from location A, the expectation is that either the first processor fetches the newly modified value in location B or the second processor fetches the newly modified value in location A, or both. However, the case in which both processors load the old values simply cannot happen.
Moreover, with the delays caused by load and store buffers, the “impossible case” can happen.
What could happen with Peterson's algorithm is that two threads running on separate processors each stores into its own slot of the particular array and then loads from the other slot. They both read the old values (0), assume that the other party is not present, and both enter the critical section. (Note that this is the sort of problem that might not occur when you test a program, but only much later.)
This problem is avoided when you use the threads synchronization primitives, whose implementations issue special instructions to force the writing of the store buffers to the cache.
