Multithreaded Programming Guide
Preface
The Multithreaded Programming Guide describes the multithreaded programming interfaces for POSIX and Solaris threads in the SolarisTM Operating Environment. This guide shows application programmers how to create new multithreaded programs and how to add multithreading to existing programs.
Although this guide covers both the POSIX and Solaris threads implementations, most topics assume a POSIX threads interest. Information applying to only Solaris threads is covered in a special chapter.
To understand this guide, a reader must be familiar with
How This Guide Is Organized
Chapter 1 gives a structural overview of threads implementation in this release.
Chapter 2 discusses the general POSIX threads library routines, emphasizing creating a thread with default attributes.
Chapter 3 covers creating a thread with nondefault attributes.
Chapter 4 covers the threads library synchronization routines.
Chapter 5 discusses changes to the operating environment to support multithreading.
Chapter 6 covers multithreading safety issues.
Chapter 7 covers the basics of compiling and debugging multithreaded applications.
Chapter 8 covers the Solaris threads (as opposed to POSIX threads) interfaces.
Chapter 9 discusses issues that affect programmers writing multithreaded applications.
Appendix A shows how code can be designed for POSIX threads.
Appendix B shows an example of building a barrier in Solaris threads.
Accessing Sun Documentation Online
The docs.sun.comSM Web site enables you to access Sun technical documentation online. You can browse the docs.sun.com archive or search for a specific book title or subject. The URL is http://docs.sun.com.
What Typographic Conventions Mean
The following table describes the typographic changes used in this book.
Table P–1 Typographic Conventions
Typeface or Symbol
Meaning
Example
AaBbCc123
 The names of commands, files, and directories; on-screen computer output
Edit your .login file.
Use ls -a to list all files.
machine_name% you have mail.
AaBbCc123
 What you type, contrasted with on-screen computer outputmachine_name% su Password:
AaBbCc123
 Command-line placeholder: replace with a real name or value
To delete a file, type rm filename.
AaBbCc123
Book titles, new words, or terms, or words to be emphasized.
Read Chapter 6 in User's Guide.
These are called class options.
You must be root to do this.
Shell Prompts in Command Examples
The following table shows the default system prompt and superuser prompt for the C shell, Bourne shell, and Korn shell.
Table P–2 Shell Prompts
Shell
Prompt
 C shell promptmachine_name%
 C shell superuser promptmachine_name#
 Bourne shell and Korn shell prompt$
 Bourne shell and Korn shell superuser prompt#
