Multithreaded Programming Guide
Destroy Read-Write Lock State
rwlock_destroy(3THR)
#include <synch.h>  (or #include <thread.h>)
int rwlock_destroy(rwlock_t *rwlp);
Use rwlock_destroy(3THR) to destroy any state associated with the read-write lock pointed to by rlwp. The space for storing the read-write lock is not freed. (For POSIX threads, see pthread_rwlock_destroy(3THR).)
Return Values
rwlock_destroy() returns zero after completing successfully. Any other return value indicates that an error occurred. When any of the following conditions occurs, the function fails and returns the corresponding value.
EINVAL
Invalid argument.
EFAULT
rwlp points to an illegal address.
Read-Write Lock Example
Example 8–1 uses a bank account to demonstrate read-write locks. While the program could allow multiple threads to have concurrent read-only access to the account balance, only a single writer is allowed. Note that the get_balance() function needs the lock to ensure that the addition of the checking and saving balances occurs atomically.
Example 8–1 Read-Write Bank Account
rwlock_t account_lock;
float checking_balance = 100.0;
float saving_balance = 100.0;
rwlock_init(&account_lock, 0, NULL);
float
get_balance() {
    float bal;
    rw_rdlock(&account_lock);
    bal = checking_balance + saving_balance;
    rw_unlock(&account_lock);
    return(bal);
void
transfer_checking_to_savings(float amount) {
    rw_wrlock(&account_lock);
    checking_balance = checking_balance - amount;
    saving_balance = saving_balance + amount;
