Multithreaded Programming Guide
Similar Synchronization Functions—Mutual Exclusion Locks
Initialize a Mutex
mutex_init(3THR)
#include <synch.h>
#include <thread.h>
int mutex_init(mutex_t *mp, int type, void *arg));
Use mutex_init(3THR) to initialize the mutex pointed to by mp. The type can be one of the following (note that arg is currently ignored). (For POSIX threads, see Initialize a Mutex.)
When a process dies while holding a USYNC_PROCESS lock, subsequent requestors of that lock hang. This is a problem for systems which share locks with client processes because the client processes can be abnormally killed. To avoid the problem of hanging on a lock held by a dead process, use USYNC_PROCESS_ROBUST to lock the mutex. USYNC_PROCESS_ROBUST adds two capabilities:
Mutexes can also be initialized by allocation in zeroed memory, in which case a type of USYNC_THREAD is assumed.
Multiple threads must not initialize the same mutex simultaneously. A mutex lock must not be reinitialized while other threads might be using it.
Mutexes With Intraprocess Scope
#include <thread.h>
mutex_t mp;
int ret;
/* to be used within this process only */
ret = mutex_init(&mp, USYNC_THREAD, 0);
Mutexes With Interprocess Scope
#include <thread.h>
mutex_t mp;
int ret;
/* to be used among all processes */
ret = mutex_init(&mp, USYNC_PROCESS, 0);
Mutexes With Interprocess Scope-Robust
#include <thread.h>
mutex_t mp;
int ret;
ret = mutex_init(&mp, USYNC_PROCESS_ROBUST, 0);
Destroy a Mutex
mutex_destroy(3THR)
#include <thread.h>
int mutex_destroy (mutex_t *mp);
Use mutex_destroy(3THR) to destroy any state associated with the mutex pointed to by mp. Note that the space for storing the mutex is not freed. (For POSIX threads, see pthread_mutex_destroy(3THR).)
Acquire a Mutex
mutex_lock(3THR)
#include <thread.h>
int mutex_lock(mutex_t *mp);
Use mutex_lock(3THR) to lock the mutex pointed to by mp. When the mutex is already locked, the calling thread blocks until the mutex becomes available (blocked threads wait on a prioritized queue). (For POSIX threads, see pthread_mutex_lock(3THR).)
Release a Mutex
mutex_unlock(3THR)
#include <thread.h>
int mutex_unlock(mutex_t *mp);
Use mutex_unlock(3THR) to unlock the mutex pointed to by mp. The mutex must be locked and the calling thread must be the one that last locked the mutex (the owner). (For POSIX threads, see pthread_mutex_unlock(3THR).)
Try to Acquire a Mutex
mutex_trylock(3THR)
#include <thread.h>
int mutex_trylock(mutex_t *mp);
Use mutex_trylock(3THR) to attempt to lock the mutex pointed to by mp. This function is a nonblocking version of mutex_lock(). (For POSIX threads, see pthread_mutex_trylock(3THR).)
