Multithreaded Programming Guide
pthread_once(3THR)
Use pthread_once(3THR) to call an initialization routine the first time pthread_once(3THR) is called. Subsequent calls to pthread_once() have no effect.
Prototype:
int	 pthread_once(pthread_once_t *once_control,
    void (*init_routine)(void));
#include <pthread.h>
pthread_once_t once_control = PTHREAD_ONCE_INIT;
int ret;
ret = pthread_once(&once_control, init_routine);
The once_control parameter determines whether the associated initialization routine has been called.
Return Values
pthread_once() returns zero after completing successfully. Any other return value indicates that an error occurred. When the following condition occurs, pthread_once() fails and returns the corresponding value.
EINVAL
once_control or init_routine is NULL.
