This example shows the contents of a valid pkginfo
file, with the five required parameters defined, as well as the BASEDIR
parameter. The BASEDIR
parameter is discussed in more detail in The path Field.
PKG=SUNWcadap NAME=Chip designers need CAD application software to design abc chips. Runs only on xyz hardware and is installed in the usr partition. ARCH=sparc VERSION=release 1.0 CATEGORY=system BASEDIR=/opt |
