Application Packaging Developer's Guide
Package Environment Variables Summary
The table below summarizes variable specification formats, location, and scope.
Table 2–2 Package Environment Variables Summary
Variable Defined In The ...
Variable Definition Format
Variable Type Being Defined
When The Variable Is Resolved
Where The Variable Is Resolved
The Variable May Be Used As Part Of The ...
pkginfo file
PARAM=value
Build
Ignored at build time
N/A
None
Install
Install time
In the pkgmap file
owner, group, path, or link target
prototype file
!PARAM=value
Build
Build time
In the prototype file and any included files
mode, owner, group, or path
Install
Build time
!search and !command commands only
pkgmk command line
PARAM=value
Build
Build time
Install
Build time
!search command only
Install time
In the pkgmap file
