Case Study Files
The i.cron and r.cron scripts
described below are executed by superuser. Editing another user's crontab file as superuser may have unpredictable results. If necessary,
change the following entry in each script:
crontab $user < /tmp/$$crontab ||
to
su $user -c "crontab /tmp/$$crontab" ||
The pkginfo Command
PKG=case7
NAME=Case Study #7
CATEGORY=application
BASEDIR=/opt
ARCH=SPARC
VERSION=Version 1.0
CLASSES=cron
The prototype File
i pkginfo
i i.cron
i r.cron
e cron /var/spool/cron/crontabs/root ? ? ?
e cron /var/spool/cron/crontabs/sys ? ? ?
The i.cron Installation Class Action Script
# PKGINST parameter provided by installation service
while read src dest
do
user=`basename $dest` ||
exit 2
(crontab -l $user |
sed -e "/#$PKGINST$/d" > /tmp/$$crontab) ||
exit 2
sed -e "s/$/#$PKGINST/" $src >> /tmp/$$crontab ||
exit 2
exit 2
rm -f /tmp/$$crontab
done
exit 0
The r.cron Removal Class Action Script
while read path
do
user=`basename $path` ||
exit 2
(crontab -l $user |
exit 2
exit 2
done
exit
crontab File #1
41,1,21 * * * * /usr/lib/uucp/uudemon.hour > /dev/null
45 23 * * * ulimit 5000; /usr/bin/su uucp -c
"/usr/lib/uucp/uudemon.cleanup" >
/dev/null 2>&1
11,31,51 * * * * /usr/lib/uucp/uudemon.poll > /dev/null
crontab File #2
0 * * * 0-6 /usr/lib/sa/sa1
20,40 8-17 * * 1-5 /usr/lib/sa/sa1
5 18 * * 1-5 /usr/lib/sa/sa2 -s 8:00 -e 18:01 -i 1200 -A
Note – If editing of a group of files will increase total file size by
more than 10K, supply a space file so the pkgadd command can allow for this increase. For more information on the space file, see Reserving Additional Space on a Target System.
