Application Packaging Developer's Guide
The checkinstall Script
The checkinstall script verifies that the patch is appropriate for this particular package. Once that is confirmed, it constructs the patch list and the patch info list, and then inserts them into the response file for incorporation into the package database.
A patch list is the list of patches that have affected the current package. This list of patches is recorded in the installed package in the pkginfo file with a line that might look like this:
PATCHLIST=patch_id patch_id ...
A patch info list is the list of patches on which the current patch is dependent. This list of patches is also recorded in the pkginfo file with a line that might look like this.
PATCH_INFO_103203-01=Installed... Obsoletes:103201-01 Requires: \ Incompatibles: 120134-01
Note –
These lines (and their format) are declared as a public interface. Any company that ships patches for Solaris packages should update this list appropriately. When a patch is delivered, each package within the patch contains a checkinstall script that performs this task. That same checkinstall script also updates some other patch-specific parameters. This is the new patch architecture, which is called Direct Instance Patching.
In this example, both the original packages and their patches exist in the same directory. The two original packages are named SUNWstuf.v1 and SUNWstuf.v2, and their patches are named SUNWstuf.p1 and SUNWstuf.p2. What this means is that it could be very difficult for a procedure script to figure out what directory these files came from, since everything in the package name after the dot (“.”) is stripped for the PKG parameter, and the PKGINST environment variable refers to the installed instance not the source instance. So the procedure scripts can find the source directory, the checkinstall script (which is always executed from the source directory) makes the inquiry and passes the location on as the variable SCRIPTS_DIR. If there had been only one package in the source directory called SUNWstuf, then the procedure scripts could have found it using $INSTDIR/$PKG.
# checkinstall script to control a patch installation.
# directory format options.
#       @(#)checkinstall 1.6 96/09/27 SMI
# Copyright (c) 1995 by Sun Microsystems, Inc.
# All rights reserved
PATH=/usr/sadm/bin:$PATH
INFO_DIR=`dirname $0`
INFO_DIR=`dirname $INFO_DIR`    # one level up
NOVERS_MSG="PaTcH_MsG 8 Version $VERSION of $PKG is not installed on this system."
ALRDY_MSG="PaTcH_MsG 2 Patch number $Patch_label is already applied."
TEMP_MSG="PaTcH_MsG 23 Patch number $Patch_label cannot be applied until all \
restricted patches are backed out."
# Read the provided environment from what may have been a request script
. $1
# Old systems can't deal with checkinstall scripts anyway
if [ "$PATCH_PROGRESSIVE" = "true" ]; then
        exit 0
fi
# Confirm that the intended version is installed on the system.
if [ "${UPDATE}" != "yes" ]; then
        echo "$NOVERS_MSG"
        exit 3
fi
# Confirm that this patch hasn't already been applied and
# that no other mix-ups have occurred involving patch versions and
# the like.
Skip=0
active_base=`echo $Patch_label | nawk '
        { print substr($0, 1, match($0, "Patchvers_pfx")-1) } '`
active_inst=`echo $Patch_label | nawk '
        { print substr($0, match($0, "Patchvers_pfx")+Patchvers_pfx_lnth) } '`
# Is this a restricted patch?
if echo $active_base | egrep -s "Patchstrict_str"; then
        is_restricted="true"
        # All restricted patches are backoutable
        echo "PATCH_NO_UNDO=" >> $1
else
        is_restricted="false"
fi
for patchappl in ${PATCHLIST}; do
        # Is this an ordinary patch applying over a restricted patch?
        if [ $is_restricted = "false" ]; then
                if echo $patchappl | egrep -s "Patchstrict_str"; then
                        echo "$TEMP_MSG"
                        exit 3;
                fi
        fi
        # Is there a newer version of this patch?
        appl_base=`echo $patchappl | nawk '
        if [ $appl_base = $active_base ]; then
                appl_inst=`echo $patchappl | nawk '
                        { print substr($0, match($0, "Patchvers_pfx")\
                result=`expr $appl_inst \> $active_inst`
                if [ $result -eq 1 ]; then
                        echo "PaTcH_MsG 1 Patch number $Patch_label is \
superceded by the already applied $patchappl."
                        exit 3
                elif [ $appl_inst = $active_inst ]; then
                        # Not newer, it's the same
                        if [ "$PATCH_UNCONDITIONAL" = "true" ]; then
                                if [ -d $PKGSAV/$Patch_label ]; then
                                        echo "PATCH_NO_UNDO=true" >> $1
                                fi
                        else
                                echo "$ALRDY_MSG"
                                exit 3;
                        fi
                fi
        fi
done
# Construct a list of applied patches in order
echo "PATCHLIST=${PATCHLIST} $Patch_label" >> $1
# Construct the complete list of patches this one obsoletes
ACTIVE_OBSOLETES=$Obsoletes_label
if [ -n "$Obsoletes_label" ]; then
        # Merge the two lists
        echo $Obsoletes_label | sed 'y/\ /\n/' | \
        nawk -v PatchObsList="$PATCH_OBSOLETES" '
        BEGIN {
                printf("PATCH_OBSOLETES=");
                PatchCount=split(PatchObsList, PatchObsComp, " ");
                for(PatchIndex in PatchObsComp) {
                        Atisat=match(PatchObsComp[PatchIndex], "@");
                        PatchObs[PatchIndex]=substr(PatchObsComp[PatchIndex], \
0, Atisat-1);
                        PatchObsCnt[PatchIndex]=substr(PatchObsComp\
[PatchIndex], Atisat+1);
                Inserted=0;
                for(PatchIndex in PatchObs) {
                        if (PatchObs[PatchIndex] == $0) {
                                if (Inserted == 0) {
                                        PatchObsCnt[PatchIndex]=PatchObsCnt\
[PatchIndex]+1;
                                        Inserted=1;
                                } else {
                                        PatchObsCnt[PatchIndex]=0;
                        printf ("%s@1 ", $0);
                next;
        END {
                        if ( PatchObsCnt[PatchIndex] != 0) {
                                printf("%s@%d ", PatchObs[PatchIndex], \
PatchObsCnt[PatchIndex]);
                printf("\n");
        } ' >> $1
        # Clear the parameter since it has already been used.
        echo "Obsoletes_label=" >> $1
        # Pass it's value on to the preinstall under another name
        echo "ACTIVE_OBSOLETES=$ACTIVE_OBSOLETES" >> $1
fi
# Construct PATCH_INFO line for this package.
tmpRequire=`nawk -F= ' $1 ~ /REQUIR/ { print $2 } ' $INFO_DIR/pkginfo `
tmpIncompat=`nawk -F= ' $1 ~ /INCOMPAT/ { print $2 } ' $INFO_DIR/pkginfo `
if [ -n "$tmpRequire" ] && [ -n "$tmpIncompat" ]
then
        echo "PATCH_INFO_$Patch_label=Installed: `date` From: `uname -n` \
          Obsoletes: $ACTIVE_OBSOLETES Requires: $tmpRequire \
          Incompatibles: $tmpIncompat" >> $1
elif [ -n "$tmpRequire" ]
then
Incompatibles: " >> $1
elif [ -n "$tmpIncompat" ]
then
          Obsoletes: $ACTIVE_OBSOLETES Requires: Incompatibles: \
$tmpIncompat" >> $1
else
          Obsoletes: $ACTIVE_OBSOLETES Requires: Incompatibles: " >> $1
fi
# Since this script is called from the delivery medium and we may be using
# dot extensions to distinguish the different patch packages, this is the
# only place we can, with certainty, trace that source for our backout
# scripts. (Usually $INST_DATADIR would get us there).
echo "SCRIPTS_DIR=`dirname $0`" >> $1
# If additional operations are required for this package, place
# those package-specific commands here.
#XXXSpecial_CommandsXXX#
exit 0
