Application Packaging Developer's Guide
clarch Utility
The clarch utility is used to archive a specific class in an ABI-style package in order to convert it to class archive format. The clarch command calls a custom archive script (archive-script) which is responsible for the creation of the custom archive in the archive directory of the package.
The format for the clarch command is:
clarch [-tuaq] [-d basedir] package archive-script class
Each option is described in the following table:
Option
Description
-a
Indicates an absolute archive. The root directory is used instead of the reloc directory.
-d basedir
Indicates the directory in which the package will be found.
-u
Indicates that the archive should be undone, which dearchives this class. The contents of the archive are replaced in the reloc directory.
-q
Indicates a quiet mode.
-t
Indicates a test mode.
package
Indicates the name of the package to operate upon.
class
Indicates the name of the class to archive.
