Solaris Tunable Parameters Reference Manual
rlim_fd_max (Solaris 8 Release)
Description
"Hard" limit on file descriptors that a single process might have open. To override this limit requires superuser privilege.
Data Type
Signed integer
Default
1024
Range
1 to MAXINT
Units
File descriptors
Dynamic?
No
Validation
None
When to Change
When the maximum number of open files for a process is not enough. Note that other limitations in system facilities can mean that a larger number of file descriptors is not as useful as it might be:
  • A 32-bit program using standard I/O is limited to 256 file descriptors. A 64-bit program using standard I/O can use up to 2 billion descriptors.
  • select(3C) is by default limited to 1024 descriptors per fd_set. Starting with the Solaris 7 release, 32-bit application code can be recompiled with a larger fd_set size (less than or equal to 65,536). A 64-bit application sees an fd_set size of 65,536, which cannot be changed.
An alternative to changing this on a system wide basis is to use the plimit(1) command. If a parent process has its limits changed by plimit, all children inherit the increased limit. This is useful for daemons such as inetd.
Commitment Level
Unstable
