The following sections explain the following categories of vi commands.
Moving around in a file
Inserting text
Changing and substituting text
Undoing changes to text
Deleting text
Checking your spelling
Formatting your file output
Repeating commands
In the previous sections you learned how to create, save, print, and exit a vi file. Now that you have created a file, you'll need to understand the concepts that are required to navigate within it. Open your practice file now, and try each of the commands that are discussed in this section.
When you start vi, the cursor is in the upper left corner of the vi screen. In command mode, you can move the cursor with a number of keyboard commands. Certain letter keys, the arrow keys, and the Return key, Back Space (or Delete) key, and the Space Bar can all be used to move the cursor when you're in command mode.
Most vi commands are case sensitive. The same command typed in lowercase and uppercase characters might have different effects.
If your machine is equipped with arrow keys, try these now. You should be able to move the cursor freely about the screen by using combinations of the up, down, right, and left arrow keys. Notice that you can only move the cursor across already existing text or input spaces.
If you're using vi from a remote terminal, the arrow keys might not work correctly. The arrow key behavior depends on your terminal emulator. If the arrow keys don't work for you, you can use the following substitutes:
Press w (“word”) to move the cursor to the right one word at a time.
Press b (“back”) to move the cursor to the left one word at a time.
Press W or B to move the cursor past the adjacent punctuation to the next or previous blank space.
Press e (“end”) to move the cursor to the last character of the current word.
Press ^ to move the cursor to the start of the current line.
Press $ to move the cursor to the end of the current line.
Press the Return key to move the cursor to the beginning of the next line down.
Press the Back Space key to move the cursor one character to the left.
Press the Space Bar to move the cursor one character to the right.
Press H (“high”) to move the cursor to the top of the screen.
Press M (“middle”) to move the cursor to the middle of the screen.
Press L (“low”) to move the cursor to the bottom of the screen.
If you move down when the cursor is at the bottom of the screen, or move up when the cursor is at the top of the screen, you will see the text scroll up or down. This scrolling can be an effective way to display more text in a short file, but it can be tedious to move this way through a long file.
You can page or scroll backward or forward through a file, a screen or a half-screen at a time. To try out these commands on paint, you might want to add text so you have a longer file to work with.
Note that paging and scrolling are fundamentally different. Scrolling actually scrolls the cursor up or down through the text a line at a time, as though it were on a paper scroll. Paging moves the cursor up or down through the text a screenful at a time. On a fast system, you might not notice the difference. However, if you're working from a remote terminal or in any other situation where your system is running slower than usual, this difference can become painfully apparent.
To scroll forward (move down) one screenful, press Ctrl-F. (Hold down the Control key and press the F key.) The cursor moves to the upper left corner of the new screen.
To scroll forward one half of a screen, press Ctrl-D.
To scroll backward (that is., move up) one screenful, press Ctrl-B.
To scroll backward one half of a screen, press Ctrl-U.
vi provides many commands for inserting text. This section introduces you to the most useful of these commands. Note that each of these commands places vi in entry mode. To use any of these commands, you must first be in command mode. Remember to press Esc to make sure you are in command mode.
Type a (append) to insert text to the right of the cursor. Experiment by moving the cursor anywhere on a line and typing a, followed by the text you want to add. Press Esc when you're finished.
Type A to add text to the end of a line. To see how this command works, position the cursor anywhere on a text line and type A. The cursor moves to the end of the line, where you can type your additions. Press Esc when you are finished.
Insert text to the left of the cursor by typing i from command mode.
Type I to insert text at the beginning of a line. The command moves the cursor from any position on that line. Press Esc to return to command mode after you type the desired text.
Use these commands to open new lines, either above or below the current cursor position.
Type o to open a line below the current cursor position. To experiment, type o followed by a bit of text. You can type several lines of text if you like. Press Esc when you are finished.
Type O to open a line above the current cursor position.
Changing text involves the substitution of one section of text for another. vi has several ways to do this, depending on circumstances.
To replace a word, position the cursor at the beginning of the word to be replaced. Type cw, followed by the new word. To finish, press Esc.
To change part of a word, place the cursor on the word, to the right of the portion to be saved. Type cw, type the correction, and press Esc.
To replace a line, position the cursor anywhere on the line and type cc. The line disappears, leaving a blank line for your new text (which can be of any length). Press Esc to finish.
To substitute one or more characters for the character under the cursor, type s, followed by the new text. Press Esc to return to command mode.
Use this command to replace the character highlighted by the cursor with another character. Position the cursor over the character and type r, followed by just one replacement character. After the substitution, vi automatically returns to command mode (you do not need to press Esc).
When you edit text and make changes to a vi file, you might occasionally wish that you had not changed something. vi's undo commands enable you to back up one operation and continue on from there.
If you make a mistake in vi or if you just change your mind after an operation is completed, you can undo your last command by pressing u immediately after the command. You do not need to press Esc after you type u. By pressing u a second time you undo the undo.
Type U to undo all changes you've made to a line. This command works only if you haven't moved the cursor off the line. You do not need to press Esc after you type U.
These vi commands delete the character, word, or line you indicate. vi stays in command mode, so any subsequent text insertions must be preceded by additional commands to enter entry mode.
To delete one character, position the cursor over the character to be deleted and type x.
The x command also deletes the space the character occupied—when a letter is removed from the middle of a word, the remaining letters will close up, leaving no gap. You can also delete blank spaces in a line with the x command.
To delete one character before (to the left of) the cursor, type X (uppercase).
To delete a word, position the cursor at the beginning of the word and type dw. The word and the space it occupied are removed.
To delete part of a word, position the cursor on the word to the right of the part to be saved. Type dw to delete the rest of the word.
To delete a line, position the cursor anywhere on the line and type dd. The line and the space it occupied are removed.
Many word processors allow you to “copy and paste” and “cut and paste” lines of text. The vi editor also includes these features. The vi command-mode equivalent of “copy and paste” is yank and put. The equivalent of “cut and paste” is delete and put.
The methods for copying or moving small blocks of text in vi involves the use of a combination of the yank, delete, and put commands.
Copying a line requires two commands: yy or Y (“yank”) and either p (“put below”) or P (“put above”). Note that Y does the same thing as yy.
To yank one line, follow these steps.
Position the cursor anywhere on the line you want to yank.
Type yy.
Move the cursor to the line above where you want to put (copy) the yanked line.
Type p.
A copy of the yanked line appears in a new line below the cursor.
To place the yanked line in a new line above the cursor, type P.
The yy command works well with a count: to yank 11 lines, for example, type 11yy. Eleven lines, counting down from the cursor, are yanked, and vi indicates this with a message at the bottom of the screen: 11 lines yanked.
You can also use the P or p commands immediately after any of the deletion commands discussed earlier. This action puts the text you deleted above or below the cursor, respectively.
Use only cursor-moving commands between yanking or deleting and putting. If you delete or yank any other text before putting the new text in place, the lines you yanked or deleted are lost.
Moving lines also requires two commands: dd (“delete”) and either p or P.
To move one line, position the cursor anywhere on the line and type dd. For example, to delete 5 lines, type 5dd.
Next, move the cursor to the line above where you want the deleted line reinserted and type p. This inserts the text on a new line below the cursor.
Alternatively, you can put the deleted line above the cursor by typing P.
Many vi commands can be preceded by a repeat factor (called a count)—a number that precedes the command and tells it how many times to repeat the operation.
Most of the commands in the previous sections take counts. For instance, 3dd repeats the command to delete a line three times, therefore deleting three lines. 2dw deletes two words, and 4x deletes four characters or spaces. You can also use counts with commands to move the cursor, such as 3w and 2Ctrl-F. In the section Summary of Basic vi Commands each command that takes a count is indicated by “[count]” before the command name.
Typing a period (.) repeats the previous text-changing command. For example, if you have just deleted a line with dd, you can move the cursor to another line and delete it by simply typing a period.
