Solaris Advanced User's Guide
Keyboard Equivalents
You can often speed up operations by using a sequence of keystrokes, called keyboard accelerators, that duplicate the operations of the mouse and menus, and of the preconfigured keyboard keys.
The following table lists several command operations and the keyboard equivalents for both SPARCTM and IA machines.
Note –
The Meta key is the <> key on SPARC keyboards and is obtained on IA keyboards by pressing Ctrl-Alt.
To use a keyboard accelerator, press and hold the first key (Meta or Ctrl-Alt together) and type the second key. For example, to cut selected text, press and hold the Meta key and press X on a SPARC system. On an IA system, press and hold Ctrl and Alt together and press X simultaneously.
Table 2–1 Keyboard Accelerators
Operation
Keyboard Equivalent
Action
Again
Meta - a
Repeats the previous operation
Copy
Meta - c
Copies the selection to the clipboard
Cut
Meta - x
Cuts the selection and puts it on the clipboard
Find
Meta - f
Finds the selection to the right of the caret
Help
Help or F1
Displays a help window with context-sensitive help for the object at the pointer location
New
Meta - n
Loads a new file
Open (File)
Meta - o
Opens a file (for example, if you've highlighted a file icon in File Manager)
Open (Window)
Meta - w
Opens an icon or closes a window to an icon
Paste
Meta - v
Copies the clipboard selection to the insertion point
Print
Meta - p
Sends the file to the printer (for example, if you've highlighted a file icon in File Manager)
Props
Meta - i
Displays the property window for the application at the pointer location
Redo
Shift-Meta - p
Undoes an Undo
Save
Meta - s
Saves the current file
Stop
Stop or Esc
Stops the current operation
Undo
Meta - u
Undoes the previous operation
