Java 2 SDK for Solaris Developer's Guide
Internal Invariants
In general, it is appropriate to frequently use short assertions indicating important assumptions concerning a program's behavior.
In the absence of an assertion facility, many programmers use comments in the following way:
 if (i%3 == 0) {
    } else if (i%3 == 1) {
    } else { // (i%3 == 2)
When your code contains a construct that asserts an invariant, you should change it to an assert. To change the above example (where an assert protects the else clause in a multiway if-statement), you might do the following:
if (i % 3 == 0) {
    } else {
        assert i%3 == 2;
Note, the assertion in the above example may fail if i is negative, as the % operator is not a true mod operator, but computes the remainder, which may be negative.
