Java 2 SDK for Solaris Developer's Guide
Control-Flow Invariants
Another good candidate for an assertion is a switch statement with no default case.
For example:
 switch(suit) {
      case Suit.CLUBS:
        break;
      case Suit.DIAMONDS:
        break;
      case Suit.HEARTS:
        break;
      case Suit.SPADES:
The programmer probably assumes that one of the four cases in the above switch statement will always be executed. To test this assumption, add the following default case:
default:
        assert false;
More generally, the following statement should be placed at any location the programmer assumes will not be reached.
 assert false;
For example, suppose you have a method that looks like this:
 void foo() {
        for (...) {
            if (...)
                return;
         // Execution should never reach this point!!!
Replace the final comment with:
assert false;
Note, use this technique with discretion. If a statement is unreachable as defined in (JLS 14.19), you will see a compile time error if you try to assert that it is unreached.
