Java 2 SDK for Solaris Developer's Guide
Source Compatibility
The addition of the assert keyword to the Java Programming Language causes existing programs that use assert as an identifier to become invalid. The addition of this keyword does not, however, cause any problems with the use of preexisting binaries (.class files). In order to ease the transition from a world where assert is a legal identifier to one where it isn't, the compiler supports two modes of operation in this release.
To enable assertions, use the following command line switch.
 -source 1.4
In the absence of this flag, the behavior defaults to "1.3" for maximal source compatibility. Support for 1.3 source compatibility is likely to be phased out over time.
