J2SE 1.4 is strongly compatible with previous versions of the Java 2 Platform. Almost all existing programs should run on J2SE 1.4 without modification. However, there are some minor potential incompatibilities that involve rare circumstances and "corner cases" that we are documenting here for completeness.
Beginning with version 1.4 of the Java 2 Platform, class javax.swing.tree.DefaultTreeModel allows a null root node. In previous versions, DefaultTreeModel would not allow a null root, even though the specification for TreeModel indicated a null root was valid. DefaultTreeModel now allows setting a null root, as well as a null root in the constructor. As part of this change, the specification for DefaultTreeModel.setRoot() has been revised. The old specification for DefaultTreeModel.setRoot() was:
Sets the root to root. This will throw an IllegalArgumentException if root is null.
The new DefaultTreeModel.setRoot() specification says:
Sets the root to root. A null root implies the tree is to display nothing, and is legal.
If a serializable inner class contains explicit references to its class object, then the computed value of the serial version UID for the class will be different in J2SE 1.3 and J2SE 1.4. The difference is due to the fact that the computation of the serial version UID is sensitive to modifications made in the javac compiler between J2SE 1.3 and J2SE 1.4.
To avoid this problem affecting your applications, we recommend that you add an explicit serial version UID to your serializable classes. You can use the serialver tool to obtain the serial version UID of classes compiled with the J2SE 1.3 javac compiler.
Beginning with J2SE 1.4.0, public static field DefaultPainter in class javax.swing.text.DefaultHighlighter is final. In previous versions of the Java 2 Platform, Standard Edition, this field was non-final.
The way in which HTML forms are modeled internally in the implementation of the Java 2 Platform has changed in J2SE 1.4.0. Previously, any attributes of a form would be stored in the attributeset of all of the children character elements. In J2SE 1.4.0, an element is created to represent the form, better matching that of the html file itself. This allows for better modeling of the form, as well as consistent writing of the form. This change was made to address bug 4200439.
This change will effect developers who relied on forms being handled loosely. As an example, pre-1.4.0 implementations would previously treat the following invalid html
<table> <form> </table> </form> |
as
<form> <table> </table> </form> |
J2SE 1.4.0 instead treats it as:
<table> <form> </form> </table> |
While this change likely will not impact many developers, there is the possibility you will need to update your code. If you had previously been expecting the attributes of the leaf Elements to contain the Form's attributes, you will now have to get the attributes from the Form Element's AttributeSet.
The value of static final field MOUSE_LAST in class java.awt.event.MouseEvent has changed to 507 beginning in J2SE 1.4.0. In previous versions of the Java 2 Platform, the value of MOUSE_LAST was 506.
Because compilers hard-code static final values at compile-time, code that refers to MOUSE_LAST and that was compiled against a pre-1.4.0 version of java.awt.event.MouseEvent will retain the old value. Such code should be recompiled with the version 1.4.0 compiler in order to work with J2SE 1.4.0.
Changes have been made to make the APIs for the CORBA technology shipped in J2SE 1.4.0 compliant to the CORBA 2.3 mapping as specified by the OMG documents referenced in CORBA Compatibility Information, available online at http://java.sun.com/j2se/1.4/compatibility-CORBA.html. Consult that document for information regarding all of the API changes related to CORBA functionality between J2SE v1.3 and v1.4.0, as well as a listing of all OMG specifications with which J2SE 1.4.0 complies.
Beginning with J2SE 1.4.0, ObjectOutputStream's public one-argument constructor requires the "enableSubclassImplementation" SerializablePermission when invoked (either directly or indirectly) by a subclass which overrides ObjectOutputStream.putFields or ObjectOutputStream.writeUnshared.
Also beginning with J2SE 1.4.0, ObjectInputStream's public one-argument constructor requires the "enableSubclassImplementation" SerializablePermission when invoked (either directly or indirectly) by a subclass which overrides ObjectInputStream.readFieldsor ObjectInputStream.readUnshared.
This change will not affect the great majority of applications. However, it will affect any ObjectInputStream/ObjectOutputStream subclasses which override the putFields or readFields methods without also overriding the rest of the serialization infrastructure.
The Javac bytecode compiler in J2SE 1.4.0 is more strict than in previous versions in enforcing compliance with the Java Language Specification. The new compiler may not compile existing code that does not strictly conform to the Java Language Specification, even though that code may have compiled with earlier versions of the compiler.
The following are some examples of situations in which the J2SE 1.4.0 compiler is stricter.
The compiler now detects unreachable empty statements as required by the language specification. Here are two examples of fairly common cases that the compiler now detects and rejects.
return 0;/* exit success */; |
and
{ return f(); } catch (Whatever e) { throw new Whatever2(); }; |
Note the extra semicolon in both cases, which the compiler now correctly regards as unreachable empty statements. In addition, some automatically generated source code may generate unreachable empty statements.
The compiler now rejects import statements that import a type from the unnamed namespace. Previous versions of the compiler would accept such import declarations, even though they were arguably not allowed by the language (because the type name appearing in the import clause is not in scope). The specification is being clarified to state clearly that you cannot have a simple name in an import statement, nor can you import from the unnamed namespace.
To summarize, the syntax
import SimpleName; |
is no longer legal. Nor is the syntax
import ClassInUnnamedNamespace.Nested; |
which would import a nested class from the unnamed namespace. To fix such problems in your code, move all of the classes from the unnamed namespace into named namespace.
As of J2SE 1.4.0, the javac bytecode compiler uses "-target 1.2" by default as opposed to the previous "-target 1.1" behavior. See the reference page for the javac compiler at http://java.sun.com/j2se/1.4/docs/tooldocs/solaris/javac.html for descriptions of these behaviors. One of the changes involved in targeting 1.2 is that the compiler no longer generates and inserts method declarations into class files when the class inherits unimplemented methods from interfaces. These inserted methods, like all other non-private methods, are included in the default serialVersionUID computation. As a result, if you define an abstract serializable class which directly implements an interface but does not implement one or more of its methods, then its default serialVersionUID value will vary depending on whether it is compiled with the J2SE 1.4 version of javac or a previous javac.
For background information on these methods inserted by earlier versions of javac, see the report for bug 4043008, available online at http://java.sun.com/jdc/bugParade/bugs/4043008.html.
Source incompatibility - The JDBC 3.0 API, included as part of the J2SE 1.4, introduces two new interfaces and adds several new methods to existing interfaces. Drivers and applications that use earlier versions of the JDBC API are binary compatible with the J2SE 1.4 and will run with no problem. However, the changes made in the JDBC 3.0 API are not source compatible. Drivers and applications that implement the JDBC interfaces must be updated to reflect the changes in order to build successfully. Chapter 6 of The JDBC 3.0 Specification gives a complete list of what must be done to be compliant with the JDBC 3.0 API, and thereby be source compatible with J2SE 1.4.
Prior to J2SE 1.4, a FileNotFoundException would be thrown if the file type was known and the response code was greater than or equal to 400. Otherwise no exception would be thrown. The correct behavior as implemented in J2SE 1.4 is for URLConnection.getInputStream to throw an IOException for all http errors regardless of the file type and throw FileNotFoundException, which is a subclass of IOException, only if the http response indicates that the resource was not found. In other words, the FileNotFoundException is thrown only if the response code is 404 or 410. As part of this change, HttpURLConnection.getErrorStream now can be used to read the error page returned from the server. Prior to J2SE 1.4, getErrorStream always returned null. Also, method HttpURLConnection.getResponseCode works correctly in J2SE 1.4.
The assert keyword has been added to the Java Programming Language in J2SE 1.4. Because of the new keyword, existing programs that use "assert" as an identifier will not be in conformance with J2SE 1.4. The addition of this keyword does not, however, cause any problems with the use of preexisting binaries (.class files). In order to ease the transition from pre-J2SE 1.4 releases in which “assert” is a legal identifier to J2SE 1.4 where it isn't, the Javac bytecode compiler supports two modes of operation in J2SE 1.4.
In the normal mode of operation, the compiler accepts programs conforming to the specification for the previous release (J2SE 1.3). Assertions are not permitted, and the compiler generates a warning if the assert keyword is used as an identifier.
In an alternate mode of operation, the compiler accepts programs conforming to the specification for J2SE 1.4. Assertions are permitted, and the compiler generates an error message if the assert keyword is used as an identifier.
To enable assertions, use the -source 1.4 command line switch. In the absence of this flag, the behavior defaults to "1.3" for maximal source compatibility. Support for 1.3 source compatibility is likely to be phased out over time.
The API specification for interface java.applet.AppletContext has been modified to enable applet developers to stream data and objects for persistent use during a browser session. This eliminates the need for developers to use static classes to cache data and objects, but it introduces a potential binary incompatibility. Any existing applications containing classes that implement the AppletContext interface will not be compatible with the new AppletContext specification. Such classes will have to be modified to implement the revised AppletContext API. In practice, the only applications that commonly implement AppletContext are those that act as applet containers, such as JavaTM Plug-in and appletviewer. The impact of this potential incompatibility is therefore expected to be minimal.
J2SE 1.4 introduces significant changes to the Socket API, one of which is the addition of a new abstract method to the SocketImpl abstract class. Because of the new method, if a subclass of SocketImpl was created prior to J2SE 1.4, then compilation against the 1.4 javac will fail because there is no implementation provided for the new method. Note that binary compatibility is enforced, and existing class files for such a subclass will still work as expected.
Few applications subclass SocketImpl, and the impact of this potential incompatibility is expected to be minimal. Developers who do subclass SocketImpl have two ways to deal with this change:
Use a class file compiled on J2SE 1.3.x (or earlier).
Provide an implementation for the new method.
