Java 2 SDK for Solaris Developer's Guide
Preferences API
This new feature a simple API for managing user preference and configuration data. Applications require preference and configuration data to adapt to different users, environments and needs. Applications need a way to store, retrieve, and modify this data. This need is met by the Preferences API. The Preferences API is intended to replace most common uses of class java.util.Properties, rectifying many of its deficiencies, while retaining its light weight. For more information, see http://java.sun.com/j2se/1.4/docs/guide/lang/preferences.html.
