Common Desktop Environment: Desktop KornShell User's Guide
Variable Values
This section describes the types of values for some of the variables in a dtksh app-defaults file.
Defined Values
The C bindings of the interfaces to X, Xt and Motif include many nonstring values that are defined in header files. The general format of such values consists of an Xt or Xm prefix followed by a descriptive name. For example, one of the constraint values for a child of a form widget is XmATTACH_FORM. Equivalent values are specified in dtksh by dropping the prefix, just as in a Motif defaults file:
Boolean Values
You can specify a Boolean value as a parameter to a dtksh command using the words True or False; case is not significant. A Boolean result is returned as either True or False, using all lowercase letters.
