These requirements apply only in a left-to-right language environment in an English-language locale. You must make the appropriate changes for other locales.
y |
n/a |
n |
Required |
_ |
_ |
_ |
6-8 |
If your application uses an Edit menu, it contains the following choices, with the specified functionality, when the actions are actually supported by your application: |
Optional |
_ |
_ |
_ |
Undo |
Reverses the most recently executed action. The mnemonic is U. |
Optional |
_ |
_ |
_ |
Cut |
Removes the selected portion of data from the client area and puts it on the clipboard. The mnemonic is T. |
Optional |
_ |
_ |
_ |
Copy |
Copies the selected portion of data from the client area and puts it on the clipboard. The mnemonic is C. |
Optional |
_ |
_ |
_ |
Copy Link |
Copies a link of the selected portion of data from the client area and puts it on the clipboard. The mnemonic is K. |
Optional |
_ |
_ |
_ |
Paste |
Pastes the contents of the clipboard into the client area. The mnemonic is P. |
Optional |
_ |
_ |
_ |
Paste Link |
Pastes a link of the data represented by the contents of the clipboard into the client area. The mnemonic is L. |
Optional |
_ |
_ |
_ |
Clear |
Removes a selected portion of data from the client area without copying it to the clipboard and does not compress the remaining data. The mnemonic is E. |
Optional |
_ |
_ |
_ |
Delete |
Removes a selected portion of data from the client area without copying it to the clipboard. The mnemonic is D. |
Optional |
_ |
_ |
_ |
Select All |
Sets the primary selection to be all the elements in a component of the client area. |
Optional |
_ |
_ |
_ |
Deselect All |
Removes from the primary selection all the elements in a component of the client area. |
Optional |
_ |
_ |
_ |
Select Pasted |
Sets the primary selection to the last element or elements pasted into a component of the client area. |
Optional |
_ |
_ |
_ |
Reselect |
Sets the primary selection to the last selected element or elements in a component of the client area. This action is available only in components that do not support persistent selections and only when the current selection is empty. |
Optional |
_ |
_ |
_ |
Promote |
Promotes to the primary selection the current selection of a component of the client area. This action is available only for components that support persistent selections. |
_ |
_ |
_ |
The use of an Edit menu with these common editing operations yields consistency across applications. |
Recommended |
_ |
_ |
_ |
bs: |
If your application does not provide an <object-type> or Selected menu, but allows the user to select data within the window and manage settings for the selected data, then it provides a Properties ... choice as the last item in the Edit menu. |
Required |
_ |
_ |
_ |
6-9: |
This item has been deleted. |
