y |
n/a |
n |
Required |
_ |
_ |
_ |
gw: |
In a list that can be scrolled, such as a scrollable list box, do not allow the cursor to wrap. |
Required |
_ |
_ |
_ |
gx: |
Provide vertical scroll bars when some of the data is not visible in the combo box. |
Recommended |
_ |
_ |
_ |
gy: |
Provide horizontal scroll bars when elements are wider than the list box. |
Recommended |
_ |
_ |
_ |
gz: |
Display the elements in an order that is meaningful to the user. |
Recommended |
_ |
_ |
_ |
ha: |
Display an initial value from the list in the text-entry field. Display selected emphasis on the initial value so that typed text will replace the value. |
Recommended |
_ |
_ |
_ |
hb: |
Make the combination box large enough to display a minimum of six list items at a time. |
Recommended |
_ |
_ |
_ |
hc: |
When a user increases the size of the window in which the combo box is displayed, increase the number of items displayed in the combo box. |
Recommended |
_ |
_ |
_ |
hd: |
When a user decreases the size of the window in which the combo box is displayed, decrease the number of items displayed in the combo box. As a minimum, reduce the combo box to the text-entry field and a list box with one entry displayed. If the window is sized so that two list items cannot be displayed, clip the combo box. |
