Common Desktop Environment: ToolTalk Messaging Overview
Message Delivery Format
Deliveries are indicated by the following indicated:
Tt_message => procid recipient_procid
Table 4-4 dexplains the messages you may receive during a dispatch trace.
Table 4-4 Reasons for Dispatch Trace
Message
Explanation
tt_message_send
The message to send.
tt_message_reject
The message was rejected.
tt_message_fail
The message failed.
tt_message_reply
The reply to a message.
tt_session_join
The session to join.
tt_file_join
The file to join.
tt_message_reply
A client called the indicated function.
tt_message_send_on_exit
ttsession is dispatching on_exit messages for a client that disconnected before calling tt_close.
tt_message_accept
ttsession is dispatching messages that had been blocked while a ptype was being started. The started client has now called either tt_message_accept or tt_message_reply to indicate that the ptype should be unblocked.
TT_ERR_PTYPE_START
A ptype instance was started to receive the message, but the start command exited before it connected to ttsession.
TT_ERR_PROCID
ttsession lost its connection to the client that was working on this request.
ttsession -> ttsession
Another session wants this session to find recipients for the message.
ttsession <- ttsession
Another session wants to update (for example, fail) a message originating in this session.
