Korean Solaris User's Guide
Printing with the mp Utility
The enhanced mp(1)print filter is available in the Solaris 9 environment. It can be used to print eitherko files in ko locale or UTF-8 files in ko.UTF-8 locales.
The output from the utility is standard PostScript, and can be sent to any PostScript printer.
To print with the mp utility, type the following:
system% mp filename | lp
You can also use the utility as a filter, as the utility accepts stdin stream:
system% cat  filename | mp | lp
You can set the utility as a printing filter for a line printer. For example, the following command sequence tells the printer service LP that the printer lp1 accepts only mp format files. This command line also installs the printer lp1 on port /dev/ttya. See the lpadmin (1m) man page for more details.
system% lpadmin -p lp1 -v /dev/ttya -I MP
system% accept lp1
system% enable lp1
You can add the lpfilter utility for a filter by using the lpfilter(1M) command as follows:
system% lpfilter -f filtername -F pathname
The lpfilter command tells LP that a converter (in this case, xutops) is available through the filter description file named pathname. The pathname can be determined as follows:
Input types: simple
Output types: MP
Command: /usr/bin/mp
The filter converts the default type file input to PostScript output using /usr/bin/mp.
To print a UTF-8 text file, use the following command:
system% lp -T MP UTF-8-file
For more details on the mp(1) command, refer to the mp(1) man page.
