To print an EUC file, use the following command:
system% lp euc-filename |
To print a Packed format file on a printer that supports this format, you can use the following command:
system% lp -T PACK PACK-filename |
To print a Johap format file on a printer that supports this format, you can use the following command:
system% lp -T JOHAP JOHAP-filename |
For more information on setting up the Packed or Johap filters, see Korean Solaris System Administrator's Guide.
To print a ko.UTF-8 file to an EUC printer, type the following commands:
The first line converts the file to an EUC file. The print out will be missing any characters that are not defined in EUC.
system% iconv -f ko_KR-UTF-8 -t ko_KR-euc ko.UTF-8_filename >euc-filename system% lp euc-filename |
The first line converts the file to a Johap file.
system% iconv -f ko_KR-UTF-8 -t ko_KR-johap92 ko.UTF-8_filename > johap92-filename system% lp johap92-filename |
