Korean Solaris User's Guide
Customizing the Lookup Window from the Lookup Table Dialog
Graphic
You can control the appearance of the lookup window by choosing one of the four options listed:
You can also specify the maximum rows and columns for the lookup choices that can be displayed on a single popup. You can specify the labels used for lookup choices. The options are upper case or lower case alphabets or numbers.
