Korean Solaris User's Guide
Customizing the on/off Key from General Dialog
You can customize the key sequence to turn on/off locale specific input. To add a key sequence, perform the following steps:
  1. Press the Add button.
    You will see the Add Key popup.
  2. Press the key to be added and OK.
    The key pressed is added to the conversion key list.
    To remove any key from the list:
    Select the key from the list and press Remove.
    Note -
    The customized key sequence will not take effect until you restart htt.
