KCMS Application Developer's Guide
Constraints When Using Operation Hints
Because of constraints in the CMM or in the specific profile, not all of the above operations may be supported. Also, some CMMs may offer additional custom operations. Your application can use KcsGetAttribute() and supply the KcsAttrSupportedOperations attribute to determine which operations are supported by a given profile.
Specifying any single or combination of operation load hints to the KcsLoadProfile() function has no effect. KCMS equates this to KcsOpAll. When the application calls KcsConnectProfiles(), KCMS automatically loads all the transforms to support the full range of operations.
Your application cannot specify KcsOpAll as an argument to KcsEvaluate().
