KCMS Application Developer's Guide
KcsCharacterizationData
typedef struct KcsCharacterizationData_s {
      KcsMeasurementBase          aBase;
      union {                    /* Place holder */
            long pad;
      } oBase;
      union {
           KcsMeasurementSample      patch[KcsExtendableArray];
      } val;
 } KcsCharacterizationData;
KcsUpdateProfile() uses data in KcsCharacterizationData to recharacterize a profile. Note that monitor device profiles do not require a KcsCharacterizationData structure to be recalibrated by the default KCMS CMM, because the profiles use white-point and colorants. However, scanner device profiles do require one. Another CMM may require that this structure be defined for updating a monitor profile.
The field descriptions for this structure are the same as those for KcsCalibrationData.
