KCMS Application Developer's Guide
KcsOptimizationType
typedef unsigned long KcsOptimizationType;
KcsOptimizationType is the data type of 1 of the arguments to the KcsOptimizeProfile() function.
KcsOptimizationType indicates the types of optimization that should be performed on a profile. It can have any of the following values, alone or in combination. Note that these are only hints.
 #define KcsOptNone                                   (0)
 #define KcsOptAccuracy                               (1<<0)
 #define KcsOptSpeed                                  (1<<1)
 #define KcsOptSize                                   (1<<2)
