KCMS Application Developer's Guide
Example: Using icSigNumTag and icSigListTag
Example 5-1 shows you how to use icSigNumTag and icSigListTag.
Example 5-1 icSigNumTag and icSigListTag
#include <kcms/kcs.h>
 KcsAttributeValue                    attrValue, *attrPtr;
 int                    i;
 char                    *tmp;
 /* Set the value of countSupplied */
 attrValue.base.countSupplied = 1;
 attrValue.base.type = KcsULong;
 /* Get the number of attributes in the profile */
 status = KcsGetAttribute(profile, icSigNumTag, &attrValue);
 if (status != KCS_SUCCESS) {
     KcsFreeProfile(profile);
     exit(1);
 /* Make space to get a list of all tags */
 size = sizeof(KcsAttributeBase) + sizeof(long)*attrValue.val.uLongVal[0];
 if ((attrPtr = (KcsAttributeValue *)malloc(size)) == NULL) {
     perror("malloc failed : ");
     exit(1);
 /* Get the list of tags */
 attrPtr->base.type = KcsULong;
 attrPtr->base.sizeOfType = sizeof(long);
 attrPtr->base.countSupplied = attrValue.val.uLongVal[0];
 status = KcsGetAttribute(profile, icSigListTag, attrPtr);
     free (attrPtr);
     exit(1);
 /* Print the list */
 printf("Number of tags = %d\n", attrPtr->base.countSupplied);
 for (i=0; i<attrPtr->base.countSupplied; i++) {
     tmp = (char *)&attrPtr->val.uLongVal[i];
     printf("Tag # = %d, Tag Hex = 0x%x, Tag Ascii = %c%c%c%c\n", i,
         attrPtr->val.uLongVal[i]; *tmp, *(tmp+1), *(tmp+2), *(tmp+3));
 free (attrPtr);
