Arrays of Numbers
These arrays are variable in length and type. They are implemented with
the icAny constant instead of pointers. The icAny constant is a single-byte array that allows you to extend the data
structure by allocating more data.
icInt8Number
typedef struct {
icInt8Number data[icAny];
} icInt8Array;
icUInt8Number
typedef struct {
icUInt8Number data[icAny];
} icUInt8Array;
icInt16Number
typedef struct {
icInt16Number data[icAny];
} icInt16Array;
icUInt16Number
typedef struct {
icUInt16Number data[icAny];
} icUInt16Array;
icInt32Number
typedef struct {
icInt32Number data[icAny];
} icInt32Array;
icUInt32Number
typedef struct {
icUInt32Number data[icAny];
} icUInt32Array;
icInt64Number
typedef struct {
icInt64Number data[icAny];
} icInt64Array;
icUInt64Number
typedef struct {
icUInt64Number data[icAny];
} icUInt64Array;
icS15Fixed16Number
typedef struct {
icS15Fixed16Number data[icAny];
} icS15Fixed16Array;
icU16Fixed16Number
typedef struct {
icU16Fixed16Number data[icAny];
} icU16Fixed16Array;
icCrdInfo
typedef struct {
icUInt32Number count; /* Char count includes NULL */
icInt8Number desc[icAny]; /* NULL terminated string */
} icCrdInfo;
icCurve
typedef struct {
icUInt32Number count; /* Number of entries */
icUInt16Number data[icAny]; /* The actual table data, real
* number is determined by count
* Interpretation depends on data
* use with a given tag */
} icCurve;
icData
typedef struct {
icUInt32Number dataFlag; /* 0 = ascii, 1 = binary */
icInt8Number data[icAny]; /* Data,size determined from tag */
} icData;
icDateTimeNumber
/* The base date time number */
typedef struct {
icUInt16Number year;
icUInt16Number month;
icUInt16Number day;
icUInt16Number hours;
icUInt16Number minutes;
icUInt16Number seconds;
} icDateTimeNumber;
icDescStruct
typedef struct {
icSignature deviceMfg; /* Device Manufacturer */
icSignature deviceModel; /* Decvice Model */
icUInt64Number attributes; /* Device attributes */
icTechnologySignature technology; /* Technology signature */
icInt8Number data[icAny]; /* Descriptions text follows */
/* Data that follows is of this form, this is an icInt8Number
* to avoid problems with a compiler generating bad code as
* these arrays are variable in length.
* icTextDescription deviceMfgDesc; * Manufacturer text
* icTextDescription modelDesc; * Model text */
} icDescStruct;
icLut8
/* lut8, input & output tables are always 256 bytes in length */
typedef struct {
icUInt8Number inputChan; /* Number of input channels */
icUInt8Number outputChan; /* Number of output channels */
icUInt8Number clutPoints; /* Number of clutTable grid points */
icInt8Number pad;
icS15Fixed16Number e00; /* e00 in the 3 * 3 */
icS15Fixed16Number e01; /* e01 in the 3 * 3 */
icS15Fixed16Number e02; /* e02 in the 3 * 3 */
icS15Fixed16Number e10; /* e10 in the 3 * 3 */
icS15Fixed16Number e11; /* e11 in the 3 * 3 */
icS15Fixed16Number e12; /* e12 in the 3 * 3 */
icS15Fixed16Number e20; /* e20 in the 3 * 3 */
icS15Fixed16Number e21; /* e21 in the 3 * 3 */
icS15Fixed16Number e22; /* e22 in the 3 * 3 */
icUInt8Number data[icAny]; /* Data follows see spec for size */
* icUInt8Number inputTable[inputChan][256]; * The input table
* icUInt8Number clutTable[icAny]; * The clut table
* icUInt8Number outputTable[outputChan][256]; * The output table
} icLut8;
icLut16
/* lut16 */
typedef struct {
icInt8Number pad; /* Padding for byte alignment */
icUInt16Number inputEnt; /* Number of input table entries */
icUInt16Number outputEnt; /* Number of output table entries */
icUInt16Number data[icAny]; /* Data follows see spec for size */
* icUInt16Number inputTable[inputChan][icAny]; * The input table
* icUInt16Number clutTable[icAny]; * The clut table
* icUInt16Number outputTable[outputChan][icAny]; * The output table
} icLut16;
icMeasurement
typedef struct {
icStandardObserver stdObserver; /* Standard observer */
icXYZNumber backing; /* XYZ for backing material */
icMeasurementGeometry geometry; /* Measurement geometry */
icMeasurementFlare flare; /* Measurement flare */
icIlluminant illuminant; /* Illuminant */
} icMeasurement;
Each field in icMeasurement is an enumerated
type. For details on each field, see the following:
icNamedColor2
* icNamedColor2 takes the place of icNamedColor, approved at the
* SIGGRAPH 95, ICC meeting.
typedef struct {
icUInt32Number vendorFlag; /* Bottom 16 bits for IC use */
icUInt32Number count; /* Count of named colors */
icUInt32Number nDeviceCoords; /* Number of device coordinates */
icInt8Number prefix[32]; /* Prefix for each color name */
icInt8Number suffix[32]; /* Suffix for each color name */
icInt8Number data[icAny]; /* Named color data follows */
* icInt8Number root1[32]; * Root name for first color
* icUInt16Number pcsCoords1[icAny]; * PCS coordinates of first color
* icUInt16Number deviceCoords1[icAny]; * Device coordinates of first color
* icInt8Number root2[32]; * Root name for second color
* icUInt16Number pcsCoords2[icAny]; * PCS coordinates of first color
* icUInt16Number deviceCoords2[icAny]; * Device coordinates of first color
* Repeat for name and PCS and device color coordinates up to (count-1)
* NOTES:
* PCS and device space can be determined from the header.
* PCS coordinates are icUInt16 numbers and are described in the ICC
* specification. Only 16 bit CIELAB and CIEXYZ are allowed. The number of
* coordinates is consistent with the headers PCS.
* Device coordinates are icUInt16 numbers where 0x0000 represents
* the minimum value and 0xFFFF represents the maximum value.
* If the nDeviceCoords value is 0, this field is not given.
} icNamedColor2;
icProfileSequenceDesc
typedef struct {
icUInt32Number count; /* Number of descriptions */
icUInt8Number data[icAny]; /* Array of description struct */
} icProfileSequenceDesc;
icScreening
typedef struct {
icUInt32Number screeningFlag; /* Screening flag */
icUInt32Number channels; /* Number of channels */
icScreeningData data[icAny]; /* Array of screening data */
} icScreening;
icScreeningData
typedef struct {
icS15Fixed16Number frequency; /* Frequency */
icS15Fixed16Number angle; /* Screen angle */
icSpotShape spotShape; /* Spot Shape encodings */
} icScreeningData;
icText
typedef struct {
icInt8Number data[icAny]; /* Variable array of chars */
} icText;
icTextDescription
typedef struct {
icUInt32Number count; /* Description length */
icInt8Number data[icAny]; /* Descriptions follow */
* icInt8Number desc[count] * NULL terminated ascii string
* icUInt32Number ucLangCode; * UniCode language code
* icUInt32Number ucCount; * UniCode description length
* icInt16Number ucDesc[ucCount]; * The UniCode description
* icUInt16Number scCode; * ScriptCode code
* icUInt8Number scCount; * ScriptCode count
* icInt8Number scDesc[67]; * ScriptCode Description
} icTextDescription;
icUcrBg
typedef struct {
icInt8Number data[icAny]; /* The Ucr BG data */
* Data that follows is of this form. UcrBg is a icInt8Number
* to avoid problems with a compiler as
* these are variable-length arrays.
* icUcrBgCurve ucr; * Ucr curve
* icUcrBgCurve bg; * Bg curve
* icInt8Number string; * UcrBg description string
} icUcrBg;
icUcrBgCurve
/* Structure describing either a UCR or BG curve */
typedef struct {
icUInt32Number count; /* Curve length */
icUInt16Number curve[icAny]; /* The array of curve values */
} icUcrBgCurve;
icViewingCondition
typedef struct {
icXYZNumber illuminant; /* In candelas per metre sq'd */
icXYZNumber surround; /* In candelas per metre sq'd */
icIlluminant stdIluminant; /* See icIlluminant defines */
} icViewingCondition;
icXYZArray
typedef struct {
icXYZNumber data[icAny]; /* Variable array of XYZ numbers */
} icXYZArray;
icXYZNumber
typedef struct {
icS15Fixed16Number X;
icS15Fixed16Number Y;
icS15Fixed16Number Z;
} icXYZNumber;
