KCMS Application Developer's Guide
Optimizing Profiles
Once a color profile has been loaded, a CMM may be able to optimize it. Using the KcsOptimizeProfile()function, your application can optimize a profile (an individual profile or a CCP) in two ways:
Because optimization can take a long time, your application can provide a callback similar to the one used with KcsEvaluate().
After your application optimizes a profile, it must call KcsSaveProfile() to save the profile for future use. Then it can use this profile with KcsLoadProfile() to avoid the slow performance of KcsOptimizeProfile().
Saving an optimized profile has some potential implications. The optimization may indirectly affect future operations on the profile. For example, if the profile is optimized for size, portions of the profile needed only for highest accuracy may be discarded, resulting in compromised accuracy.
