virtual
KcsStatus absRead(const long index,
const long bytesWanted,
void *buffer,
const char *callersName = NULL);
Absolute read an I/O object already opened or allocated.
Supply a count of number of bytes to read and a buffer.
virtual
KcsStatus absWrite(const long index,
const long numBytes2Write,
const void *buffer,
Absolute write to some number of bytes in numBytes2Write from the buffer to the data store at the current
position of the cursor
virtual
KcsStatus copyData(KcsIO *anotherIO);
Copies all data in I/O object to anotherIO object.
static KcsIO * createIO(KcsStatus *aStatus,
const KcsProfileDesc *aDesc);
Static method that creates an I/O object, by calling either
a KcsIO derivative constructor within the KCMS library
or a run-time loadable constructor.
virtual
KcsStatus getEOF(long *theEOF) = 0;
Returns the end-of-file (EOF) position.
virtual
long getOffset();
Returns the permanent offset into the I/O object.
virtual
KcsIOType getType() = 0;
Returns the type of I/O object.
virtual
int isEqual(KcsIO *anotherIO) = 0;
Determines if this I/O object and another I/O object are
working on the same data stores. The base offsets must also be the same for
them to return true.
KcsIO(KcsStatus *status,
const unsigned long absBaseOffset = 0);
Constructor that initializes the baseOffset
data member with the values passed in.
virtual ~KcsIO();
Destructor.
virtual
KcsStatus relRead(const long bytesWanted,
void *buffer,
const char *callersName = NULL) = 0;
Reads bytesWanted from the I/O object
from the current position of the cursor. Positions the cursor after the last
byte read.
virtual
KcsStatus relWrite(const long numBytes2Write,
const void *buffer,
Relative write of the number of bytes in numBytes2Write from the buffer to the data store
at the current position of the cursor. Positions the cursor after the last
byte written.
virtual
KcsStatus replaceData(const unsigned long offset,
const unsigned long oldSize,
const void *buffer,
const unsigned long newSize,
Replaces bytes of different lengths in an
I/O object. Specifies where to start writing and size of old and new data.
If the old data is longer than the new data, the I/O object is compressed.
If the new data is longer than the old data, everything after the old data
is moved to the end of the I/O object. If an error occurs, the cursor is where
it was before the error occurred.
virtual
KcsStatus setCursorPos(long position,
const KcsIOPosition mode= KCS_OFS,
Sets the I/O object cursor to a caller-supplied position.
Positions the I/O object cursor to a specific
spot in the object. Mode is defined by the enum KcsFilePosition.
virtual
KcsStatus setEOF(long theEOF) = 0;
Sets the EOF to a caller-supplied position. If the new
EOF is greater than the old EOF, the storage for the new space is undefined.
virtual
void setOffset(long theOffset);
Sets the base offset to a specified position.
