KCMS Test Suite User's Guide
Creating An Alternate Initialization File
You can create an alternate initialization file if, for example, you customized scripts for your CMM.
To create the file (see Example 2-1),
  1. Use a text editor to save a copy of icc.ini under a new filename, for example alternate.ini.
  2. Add (or remove) test script name(s) in the file list.
  3. Change the value immediately following the [NumberOfTests] field to update the number of tests.
