KCMS Test Suite User's Guide
Recording Test Script Results To a Log File
For each script file executed, results are recorded in a log file. All the log files can be found in the kcmstest/log directory. The log file name is the name of the script file, with the .scr file extension replaced by the .log extension. If, for example, the test script name is IC_eval.scr, the log file name is IC_eval.log.
One exception to this naming scheme is if you enter all as the test script name. See "Starting the kcmstest Command" for details on this entry. In this case, the log file name is testall.log.
Two versions of a log file may exist at any given time: the current and the previous version. The previous version has its extension changed to .bak.
Example 2-3 is the log file output created from the test script shown in Example 2-2.
Example 2-3 Log File Output
Parsing a KcsLoadProfile Command
         Profile Reference = scanner
         Profile File Name = kcmsEKls3510.inp
         Profile Handling = By File
         Profile Load Hint = LoadWhenNeeded;
         Profile Load Hint = UnLoadwhenNeeded;
         Profile Operation Hint = Image;
         Load Hint =   2024000
         Thu Jul 25 08:16:07 1996
Completed KcsLoadProfile command, status =    0
         Profile Reference = printer
         Profile File Name = kcmsEKsunnws.out
         Load Hint =   2024000
Parsing a KcsConnectProfiles Command
         Profile Reference = scan-print
         Number of Profiles in Connect = 2
         Operation Hint =     20001
Completed KcsConnectProfiles command, status =    0
         Thu Jul 25 08:16:08 1996
Parsing a KcsEvaluate Command
         Source Layout = RGBInterLeaved;
         Destination Layout = RGBInterLeaved;
         Input Image Name = macbeth_1550.tif
         Output Image Name = None
Completed KcsEvaluate command, status =    0
         364800.000000 pixels processed in 0.621338 seconds.
         The processing rate = 587120.062500 pixels/second.
Parsing a Free Profile command
          Profile reference =scanner
Completed KcsFreeProfile command, status =    0
          Profile reference = printer
          Profile reference = scan-print
