KCMS Test Suite User's Guide
Cross-Category API Functions And Script Commands
The KcsAvailable(), KcsCreateProfile(), KcsFreeProfile(), KcsModifyLoadHints(), KcsSaveProfile(), and KcsSetCallback() functions in the KCMS framework API are not addressed directly as a testing category in a single script. Each of these functions is exercised in the course of performing normal testing.
In addition, the LOG: command is not associated with a particular KCMS API function. Instead it serves to show comment data in the test scripts.
Table 4-2 Testing the SAVE: Command
Category
Script Name
Connecting Profiles
IC_conerr.scr
Getting and Setting Attributes
IC_attr1.scr
Updating Profiles
IC_update1.scr, IC_update2.scr
Enhancements
IC_gray.scr, IC_pacbug.scr, IC_sun_update.scr, IC_updatewin.scr, IC_xprofilesav.scr, IC_xprofilesavremote.scr, IC_xprofilesavroot.scr
