KCMS Test Suite User's Guide
Using auto-kcmstest-root
Certain test scripts require that you be root to run them. You would use these tests if, for example, you wanted to create an X Window System profile in a root-owned directory. To run these scripts, a second automated script called auto-kcmstest-root is provided.
To run the auto-kcmstest-root script,
  1. Become superuser.
    %su
  2. Provide one argument: the KCMSROOT environment variable, for example
    #./auto-kcmstest-root /opt/SUNWddk/kcms
    Note that if you are in the directory containing auto-kcmstest-root, no argument is required.
