KCMS Test Suite User's Guide
Attribute Test 2
Script Name
IC_attr2.scr
Concept
IC_attr2.scr creates a new profile and sets a variety of attributes. It gets the attributes and verifies that they have been properly set. It saves the profile, frees it, reloads the saved profile, and again gets the attributes.
Description
This script demonstrates that the KCMS framework can set the attributes of a profile it creates. After it creates the profile, it uses the SETATTR: command to set the attributes. Then it uses the GETATTR: command to get all the attributes it set. The script saves the profile and frees it from memory. Then it reloads the profile and again gets the attributes it set.
Verification
All the commands performed in this test are expected to be successfully completed. You should examine the log file to verify that:
