GSS-API Programming Guide
Basic GSS-API Data Types
These are some of the data types used by the GSS-API.
OM_uint32
The OM_uint32 is a platform-independent 32–bit unsigned integer.
gss_buffer_desc
This is the definition of the gss_buffer_desc and the gss_buffer_t pointer:
typedef struct gss_buffer_desc_struct {
        size_t length;
        void *value;
} gss_buffer_desc, *gss_buffer_t;
gss_OID_desc
This is the definition of the gss_OID_desc and the gss_OID pointer:
typedef struct gss_OID_desc_struct {
        OM_uint32 length;
        void*elements;
} gss_OID_desc, *gss_OID;
gss_OID_set_desc
This is the definition of the gss_OID_set_desc and the gss_OID_set pointer:
typedef struct gss_OID_set_desc_struct  {
        size_t  count;
        gss_OID elements;
} gss_OID_set_desc, *gss_OID_set;
gss_channel_bindings_struct
This is the definition of the gss_channel_bindings_struct structure and the gss_channel_bindings_t pointer:
typedef struct gss_channel_bindings_struct {
        OM_uint32 initiator_addrtype;
        gss_buffer_desc initiator_address;
        OM_uint32 acceptor_addrtype;
        gss_buffer_desc acceptor_address;
        gss_buffer_desc application_data;
} *gss_channel_bindings_t;
