GSS-API Programming Guide
server_establish_context()
This calls gss_accept_sec_context() as part of a context-establishment loop.
Example A–13 server_establish_context()
 * Function: server_establish_context
 * Purpose: establishses a GSS-API context as a specified service with
 * an incoming client, and returns the context handle and associated
 * client name
 * Arguments:
 *      s               (r) an established TCP connection to the client
 *      service_creds   (r) server credentials, from gss_acquire_cred
 *      context         (w) the established GSS-API context
 *      client_name     (w) the client's ASCII name
 * Returns: 0 on success, -1 on failure
 * Effects:
 * Any valid client request is accepted.  If a context is established,
 * its handle is returned in context and the client name is returned
 * in client_name and 0 is returned.  If unsuccessful, an error
 * message is displayed and -1 is returned.
int server_establish_context(s, server_creds, context, client_name, ret_flags)
     int s;
     gss_cred_id_t server_creds;
     gss_ctx_id_t *context;
     gss_buffer_t client_name;
     OM_uint32 *ret_flags;
     gss_buffer_desc send_tok, recv_tok;
     gss_name_t client;
     gss_OID doid;
     OM_uint32 maj_stat, min_stat;
     gss_buffer_desc    oid_name;
        char *mechStr;
     *context = GSS_C_NO_CONTEXT;
     do {
          if (recv_token(s, &recv_tok) < 0)
               return -1;
          if (verbose && log) {
              fprintf(log, "Received token (size=%d): \n", recv_tok.length);
              print_token(&recv_tok);
          maj_stat =
               gss_accept_sec_context(&min_stat,
                                      context,
                                      server_creds,
                                      &recv_tok,
                                      GSS_C_NO_CHANNEL_BINDINGS,
                                      &client,
                                      &doid,
                                      &send_tok,
                                      ret_flags,
                                      NULL,     /* ignore time_rec */
                                      NULL);    /* ignore del_cred_handle */
          if (maj_stat!=GSS_S_COMPLETE && maj_stat!=GSS_S_CONTINUE_NEEDED) {
               display_status("accepting context", maj_stat, min_stat);
               (void) gss_release_buffer(&min_stat, &recv_tok);
               return -1;
          if (send_tok.length != 0) {
                  fprintf(log,
                          "Sending accept_sec_context token (size=%d):\n",
                          send_tok.length);
                  print_token(&send_tok);
               if (send_token(s, &send_tok) < 0) {
                    fprintf(log, "failure sending token\n");
                    return -1;
               (void) gss_release_buffer(&min_stat, &send_tok);
              if (maj_stat == GSS_S_CONTINUE_NEEDED)
                  fprintf(log, "continue needed...\n");
              else
                  fprintf(log, "\n");
              fflush(log);
     } while (maj_stat == GSS_S_CONTINUE_NEEDED);
     /* display the flags */
     display_ctx_flags(*ret_flags);
         maj_stat = gss_oid_to_str(&min_stat, doid, &oid_name);
         if (maj_stat != GSS_S_COMPLETE) {
             display_status("converting oid->string", maj_stat, min_stat);
             return -1;
                mechStr = (char *)__gss_oid_to_mech(doid);
         fprintf(log, "Accepted connection using mechanism OID %.*s (%s).\n",
                 (int) oid_name.length, (char *) oid_name.value,
                        (mechStr == NULL ? "NULL" : mechStr));
         (void) gss_release_buffer(&min_stat, &oid_name);
     maj_stat = gss_display_name(&min_stat, client, client_name, &doid);
          display_status("displaying name", maj_stat, min_stat);
          return -1;
     return 0;
