After the mechanism has been put in the form of a gss_OID
, you can do the actual work, so main() now calls the function call_server() with much the same arguments as on the command line.
call_server(hostname, port, g_mechOid, service_name, deleg_flag, msg, use_file);
(use_file is a flag indicating whether the message to be sent is contained in a file or not.)
After declaring its variables, call_server() first makes a connection with the server:
if ((s = connect_to_server(host, port)) < 0) return -1;
where s is a file descriptor (an int, initially returned by a call to socket()).
connect_to_server() is a simple function that uses sockets to create a connection. Because it doesn't use the GSS-API, it's skipped here. You can see it at connect_to_server().
After the connection is established, call_server() uses the function client_establish_context() to, yes, establish the security context:
int client_establish_context(s, service_name, deleg_flag, oid, &context, &ret_flags)
s is a file descriptor representing the connection established by connect_to_server().
service_name is the network service requested (for example, nfs).
deleg_flag specifies whether or not the server may act as a proxy for the client.
oid is the mechanism.
context is the context to be created.
ret_flags is an int that specifies any flags returned by the GSS-API function gss_init_sec_context().
To initiate the context, the application uses the function gss_init_sec_context(). As this function, like most GSS-API functions, requires names to be in internal GSS-API format, the application must first translate the service name from a string to internal format. For that, it can use gss_import_name():
maj_stat = gss_import_name(&min_stat, &send_tok, (gss_OID) GSS_C_NT_HOSTBASED_SERVICE, &target_name);
This function takes the name of the service (stored in an opaque GSS_API buffer, send_tok) and converts it to the GSS_API internal name target_name. (send_tok is used to save space, instead of declaring a new gss_buffer_desc.) The third argument is a gss_OID type that indicates the name format that send_tok has. In this case, it is GSS_C_NT_HOSTBASED_SERVICE, which means a service of the format service@host. (See Name Types for other possible values for this argument.)
Once the service has been rendered in GSS-API internal format, we can proceed with establishing the context. In order to maximize portability, context-establishment should always be performed as a loop (see Context Initiation (Client)).
First, the application initializes the context to be null:
*gss_context = GSS_C_NO_CONTEXT;
token_ptr = GSS_C_NO_BUFFER;
The application now enters the loop. The loop proceeds by checking two things: the status returned by gss_init_sec_context() and the size of the token to be sent to the server (also generated by gss_init_sec_context()). If the token's size is zero, then the server is not expecting another token from the client. The pseudocode for the loop that follows looks like this:
do gss_init_sec_context() if no context was created uh-oh. Exit with error; if the status is neither "complete" nor "in process" uh-oh. Release the service namespace and exit with error; if there's a token to send to the server (= if its size is nonzero) send it; if sending it fails, oops! release the token and the service namespaces and exit with error; release the namespace for the token we've just sent; if we're not done setting up the context receive a token from the server; while the context is not complete
First, the call to gss_init_sec_context():
do { maj_stat = gss_init_sec_context(&min_stat, GSS_C_NO_CREDENTIAL, gss_context, target_name oid GSS_C_MUTUAL_FLAG | GSS_C_REPLAY_FLAG | deleg_flag, 0, NULL, &send_tok, ret_flags, NULL);
where the arguments are as follows:
The status code to be set by the underlying mechanism.
The credential handle. We use GSS_C_NO_CREDENTIAL to act as a default principal.
(gss_context) The context handle to be created.
(target_name) The service, as a GSS_API internal name.
(oid) The mechanism.
Request flags. In this case, the client requests that a) the server authenticate itself, b) that message-duplication be turned on, and c) that the server act as a proxy if requested.
No time limit for the context.
No request for channel bindings.
(token_ptr) Pointer to the token received from the server, if any.
The mechanism actually used by the server (set to NULL here because the application isn't interested in this value).
(&send_tok) The token created by gss_init_sec_context() to send to the server.
Return flags. Set to NULL because we ignore them.
You might have noticed that the client does not need to acquire credentials before initiating a context. On the client side, credential management is handled transparently by the GSS-API. That is, the GSS-API “knows” how to get credentials created by this mechanism for this principal (usually at login time). That is why the application passes gss_init_sec_context() a default credential. On the server side, however, a server application must explicitly acquire credentials for a service before accepting a context. See Acquiring Credentials.
After checking that it has a context (but not necessarily a complete one) and that gss_init_sec_context() is returning valid status, the application sees if gss_init_sec_context() has given it a token to send to the server. If it hasn't, it's because the server has indicated that it doesn't need (another) one. If it has, then send it to the server. If sending it fails, release the namespaces for it and the service, and exit. Remember, you can check for the presence of a token by looking at its length:
if (send_tok_length != 0) { if (send_token(s, &send_tok) < 0) { (void) gss_release_buffer(&min_stat, &send_tok); (void) gss_release_name(&min_stat, &target_name); return -1; } }
send_token() is not a GSS-API function; it is a basic write-to-file function written by the user. (You can see it at send_token().) Note that the GSS-API does not send or receive tokens itself. It is the responsibility of the calling applications to send and receive any tokens created by the GSS-API.
If the server doesn't have any (more) tokens to send, then gss_init_sec_context() returns GSS_S_COMPLETE. So if gss_init_sec_context()hasn't returned this value, the application knows there's another token out there to fetch. If the fetch fails it releases the service namespace and quit:
if (maj_stat == GSS_S_CONTINUE_NEEDED) { if (recv_token(s, &recv_tok) < 0) { (void) gss_release_name(&min_stat, &target_name); return -1;
Finally, the program resets its token pointers, and continues the loop until the context is completely established. Thus its do loop ends as follows:
} while (maj_stat == GSS_S_CONTINUE_NEEDED);
Having established the security context, gss-client
needs to wrap the data, send it, and then verify the “signature” that the server returns. Because gss-client
is an example program, it does various other things as well, such as
display information about the context, but we'll skip all of that in order to get the data sent out and verified. So first the program puts the message to be sent (such as “ls”) into a buffer:
if (use_file) { read_file(msg, &in_buf); } else { /* Wrap the message */ in_buf.value = msg; in_buf.length = strlen(msg) + 1; }
Before wrapping, the program checks to see if it can encrypt the data:
if (ret_flag & GSS_C_CONF_FLAG) { state = 1; else state = 0; }
And then it wraps it up:
maj_stat = gss_wrap(&min_stat, context, conf_req_flag, GSS_C_QOP_DEFAULT, &in_buf, &state, &out_buf); if (maj_stat != GSS_S_COMPLETE) { display_status("wrapping message", maj_stat, min_stat); (void) close(s); (void) gss_delete_sec_context(&min_stat, &context, GSS_C_NO_BUFFER); return -1; } else if (! state) { fprintf(stderr, "Warning! Message not encrypted.\n"); }
Thus the message stored in in_buf is to be sent to the server referenced by context, with confidentiality service and the default Quality of Protection (QOP) requested. (Quality of Protection indicates which algorithm to apply in transforming the data; it's a good idea for portability's sake to use the default whenever possible.) gss_wrap() wraps the message, puts the result into out_buf, and sets a flag (state) that indicates whether confidentiality was in fact applied in the wrapping.
The client sends the wrapped message to the server with its own send_token() function, which you've already seen in Establishing a Context:
send_token(s, &outbuf)
The program can now verify the validity of the message it sent. It knows that the server returns the MIC for the message it sent, so it retrieves it with its recv_token() function and then uses gss_verify_mic() to verify its “signature” (the MIC).
maj_stat = gss_verify_mic(&min_stat, context, &in_buf, &out_buf, &qop_state); if (maj_stat != GSS_S_COMPLETE) { display_status("verifying signature", maj_stat, min_stat); (void) close(s); (void) gss_delete_sec_context(&min_stat, &context, GSS_C_NO_BUFFER); return -1; }
gss_verify_mic() compares the MIC received with the server's token (in out_buf) with one it produces from the original, unwrapped message, held in in_buf. If the two MICs match, the message is verified. The client releases the buffer for the received token, out_buf.
To finish, call_server() deletes the context and returns to main().
